Hi @Vibsouth,
We can group several measurement by setting it in the dbase setup. Go to the dbase setup tree structure, highlight on the equipment, then select edit. Select Group/Ch tab on the right side of the screen. There will be list of your measurement point, for your example pick a number let's say 21 for group number on M1H and M1P and for channel column also 1 (because you group 2 measurements for 1 sensor i.e. the hor position and peakvue, if you have want to take 2 channel measurements for example M1H & M1V simultaneously using 2 sensors, then put 1 and 2 respectively on the ch column.)
Or just hit the help button on the AMS MHM Software, it always helpful
Cheers,
Ando
Link copied to your clipboard.
